Quick view Polymeric sku: AQUA5 AQUAMEND EPOXY MSRP: Now: $9.48 Out of stock Compare SALE Quick view Caswell sku: CWPM Casweld™ PM Soldering Rod Kit MSRP: $56.93 Was: $56.93 Now: $44.00 Out of stock Compare Quick view Polymeric sku: FASTST5 FASTSTEEL EPOXY MSRP: Now: $9.48 Out of stock Compare Quick view Glyptal sku: G1201A GLYPTAL SPRAY ON RED ENAMEL MSRP: Now: $69.56 Out of stock Compare Quick view Alvin sku: AP10101 Lab-metal 12 oz & 1 Pint Solvent 12 oz MSRP: Now: $63.24 Add to Cart Compare Quick view Caswell sku: GTSLNT Lantern Fount Sealing Kit MSRP: Now: $37.94 Add to Cart Compare Quick view Skyco sku: OSPH1G OSPHO - 1 GAL MSRP: Now: $41.73 Add to Cart Compare Quick view Aremco sku: PYRO1000 PYRO PUTTY 1000 MSRP: Now: $83.48 Add to Cart Compare Quick view Aremco sku: PYRO25 PYRO-PUTTY 2400 MSRP: Now: $68.30 Add to Cart Compare Quick view Polymeric sku: QUIKWP3 QUIKWOOD EPOXY PINE MSRP: Now: $6.95 Out of stock Compare Quick view Polymeric sku: REPQ5 REPAIRITQUIK EPOXY PUTTY - 4OZ MSRP: Now: $9.48 Out of stock Compare Quick view Anvil sku: TP250 White Wall Tire Paint - 250ml MSRP: Now: $36.69 Out of stock Compare Quick view AQUAMEND EPOXY "No Boat Should be Without it" After proper mixing, AQUAMEND® molds like clay and may be used to patch dings, scratches, cuts, gouges, and holes in fiberglass, metal, and wooden boat decks and hulls; to repair fittings, pipes, electrical connections,... MSRP: Now: $9.48 Out of stock Compare SALE Quick view Casweld™ PM Soldering Rod Kit Casweld™ PM Soldering Rod 350°F Melting Rods For Pot Metal and Thin Aluminum 4 Rod Kit (1/8" x 18") & 2 oz Flux NOW REPAIR POT METAL PARTS BEFORE PLATING WITHOUT DRILLING OR PUTTIES Download our Casweld™ Product Manual Perfect for: ... MSRP: $56.93 Was: $56.93 Now: $44.00 Out of stock Compare Quick view FASTSTEEL EPOXY "Don't weld it, FASTSTEEL it!" FASTSTEEL® is a hard kneadable, steel-reinforced, epoxy putty adhesive sealant that mixes in just one minute to provide fast repairs to items made of ferrous and aluminum metals. it comes in a handy four-ounce... MSRP: Now: $9.48 Out of stock Compare Quick view GLYPTAL SPRAY ON RED ENAMEL The outstanding all-purpose paint Although 1201 was originally developed as an insulating paint for electrical applications such as the treatment of coils and armatures, its outstanding resistance to corrosion, moisture, oil, acid, heat, dust and salt... MSRP: Now: $69.56 Out of stock Compare Quick view Lab-metal 12 oz & 1 Pint Solvent 12 oz Lab Metal® repair putty Ready-to-use aluminum-filled repair and patching compound. Spreads like paste, hardens into metal. Adheres to metal, wood, plastic, glass, fiberglass and more. Apply right from the can. No mixing of two parts, no measuring or... MSRP: Now: $63.24 Add to Cart Compare Quick view Lantern Fount Sealing Kit Seal Pinholes and Small Leaks In Lantern Founts & Fuel Tanks Contains Enough Sealer For One 1 Quart Fount Permanently Seal Lantern Founts With Our Two Part Phenol Novolac Epoxy Phenol Novolac Epoxies are a new breed of chemical resistant materials, able... MSRP: Now: $37.94 Add to Cart Compare Quick view OSPHO - 1 GAL HOW OSPHO WORKS When applied to rusted surfaces, it resists/retards rust in chemical change on drying to a tough, hard surface ready for priming. A paint job will last longer after an application of OSPHO because subsequent paint coating securely... MSRP: Now: $41.73 Add to Cart Compare Quick view PYRO PUTTY 1000 PYRO-PUTTY HI-TEMP RESTORATION PRODUCT THE ULTIMATE IN RESTORATION SOLUTIONS USING TODAY'S TECHNOLOGY Pyro-Putty 1000 Pyro-Putty 1000 is a 2 part ceramic and aluminum filled paste, that withstands temps up to 1400F. Repairs cast aluminum parts. Can be... MSRP: Now: $83.48 Add to Cart Compare Quick view PYRO-PUTTY 2400 PYRO-PUTTY HI-TEMP RESTORATION PRODUCT THE ULTIMATE IN RESTORATION SOLUTIONS USING TODAY'S TECHNOLOGY Pyro-Putty 2400 This high temperature ceramic and stainless steel metal-filled paste is ideal for repairing defects in manifolds, headers, exhaust... MSRP: Now: $68.30 Add to Cart Compare Quick view QUIKWOOD EPOXY PINE "The Woodworker's Dream" Repair, Rebuild, Restore Anything Made of Wood QUIKWOOD® is a remarkable polymer compound for instant wood repair. Easy-to-use QUIKWOOD® molds like clay, then dries like wood in 30 minutes. QUIKWOOD® is also great for... MSRP: Now: $6.95 Out of stock Compare Quick view REPAIRITQUIK EPOXY PUTTY - 4OZ Repair loose or cracked wall, floor tiles Electrical use in place of tape or plastic connector Fabricate small parts, mend holes Attach fixtures, machines, tags and signs Use for 1001 Household and Industrial purposes REPAIRITQUIK® is a hand... MSRP: Now: $9.48 Out of stock Compare Quick view White Wall Tire Paint - 250ml White Wall Tire Paint 250ml Can, 8.5 fl oz Add White Walls onto any tire with our new White Wall Tire Paint White Wall Tires hard to find? Many sizes are no longer made or very expensive. Get that classic look for your car or bike - from a can! Whitewall... MSRP: Now: $36.69 Out of stock Compare Compare Selected × OK
