FASTSTEEL EPOXY
"Don't weld it, FASTSTEEL it!"
FASTSTEEL® is a hard kneadable, steel-reinforced, epoxy putty adhesive sealant that mixes in just one minute to provide fast repairs to items made of ferrous and aluminum metals. it comes in a handy four-ounce "tootsie-roll" form with the curing agent encapsulated in the consistency eliminates drips and runs, providing "no mess" applications with no tools required for use.
- Repair ferrous metals
- Rebuild engine parts, fill cracks and seal leaks
- Form nuts & bolts, repair stripped threads
- Repair metal tools, equipment, pipes, appliances and auto bodies
- Will not rust or shrink
- Excellent filler before powder coating. Can be applied, powdercoated, then oven cured along with the powder.
Faststeel is so versatile
I'm an artist working with Faststeel, building it over a copper matrix. It hardens to an amazingly tough structure in 24 hours and fuses beautifully with copper, proving it can be used with other metals besides steel.. This stuff is so versatile. After it hardens you can sculpt, file and sand it into anything you want and even paint it. I used other similar products and was very disappointed with it crumbling, cracking and never setting up but Faststeel doesn't disappoint.
