PYRO PUTTY 1000
PYRO-PUTTY
HI-TEMP RESTORATION PRODUCT
THE ULTIMATE IN RESTORATION SOLUTIONS USING TODAY'S TECHNOLOGY
Pyro-Putty 1000
Pyro-Putty 1000 is a 2 part ceramic and aluminum filled paste, that withstands temps up to 1400F. Repairs cast aluminum parts. Can be applied up to 1/2" thick. Air sets in 2-4 hours. Heat cure at 160F for 1-2 hours.
Outstanding product!
Pyro Putty 1000 High Temp Metal Sealer I have a Volvo AQ131A engine in my boat. The number 4 exhaust port on the aluminium heads have a history of being ate out by salt water. Historically, people had to replace the head or get it welded up and re-ported incurring a fairly expensive and time consuming expense. I used this product as directed to fix the exhaust port after cleaning the affected and fairly large corroded area with a dremmel tool. It has held up to the heat from the exhaust valve beautifully. It bonds to the aluminium beautifully, appears to be harder than aluminium and can withstand temps 180 degrees hotter than aluminium. I have put approx 35 hours on my boat and feel extremely confident that it will be a long time (if ever) before I have to worry about it again. I've written very few reviews in my time but thought this product was worthy of commenting on. I wouldn't be afraid to try ANY of the Pyro Putty products after my experience with this one. This stuff really works as advertised and saved me a bunch of money!
great product, good seller
