QUIKWOOD EPOXY PINE
"The Woodworker's Dream"
Repair, Rebuild, Restore Anything Made of Wood
QUIKWOOD® is a remarkable polymer compound for instant wood repair. Easy-to-use QUIKWOOD® molds like clay, then dries like wood in 30 minutes. QUIKWOOD® is also great for wood-to-wood and wood-to-metal bonding.
- Fill holes, scratches, gauges, cracks, dry rot and knot holes
- Repair furniture, molding and frames
- Reshape woodcarvings, remold wood knobs and handles
- Can be sculpted or carved for intricate detail
- Interior and exterior applications
Pine Quikwood Putty
Works great for our needs repairing antique furniture
