- Repair loose or cracked wall, floor tiles
- Electrical use in place of tape or plastic connector
- Fabricate small parts, mend holes
- Attach fixtures, machines, tags and signs
- Use for 1001 Household and Industrial purposes
REPAIRITQUIK® is a hand -mixable, fast curing, epoxy putty that mixes in just one minute to provide fast repairs to many surfaces including metals, wood, glass, concrete, ceramics, and numerous plastic. One hour after mixing, REPAIRITQUIK® can be drilled, sawed, sanded, filed, tapped, machined, or painted. it comes in a handy four-ounce "tootsie-roll" form with the curing agent encapsulated in the contrasting color base material. The putty-like consistency eliminates drips and runs, providing "no mess" applications with no tools required for use. REPAIRITQUIK® is a general purpose epoxy putty. After proper mixing, REPAIRITQUIK® can be used in 1,001 household and industrial purposes including repair and replacement of wall tile, floor tile, cove moldings; electrical use in place of tape, ceramic, or plastic connectors, knobs, auto repairs such as bonding or trim, repairing small dents, oil pans, small parts, filling rust holes and thread locking. It seals leaks in gutters and downspouts; mends toys, appliances, lawn mowers, sports equipment, etc.; repairs air conditioning coils, ducts,; patches chipped concrete, floors, bricks, blocks; attaches fixtures, machine tags, signs; anchor bolts, screws, rods, machines, housings, etc. |
![This product can ship air and worldwide This product can ship air and worldwide](/content/images/airok.png)
Repair it Quik supplier
Although I only order a few of the same things from Caswell, I keep coming back because I know they'll have what I need and it will be shipped out right away. Very good service!
Thank you.
Very good product.
