PYRO-PUTTY
HI-TEMP RESTORATION PRODUCT
THE ULTIMATE IN RESTORATION SOLUTIONS USING TODAY'S TECHNOLOGY
Pyro-Putty 2400
This high temperature ceramic and stainless steel metal-filled paste is ideal for repairing defects in manifolds, headers, exhaust pipes, mufflers, and more. Withstands temps up to 2000F
Pyro-Putty 2400 bonds tenaciously to cast iron and steel and stainless steel, and is easy to apply, cure, machine and clean. Can be applied up to 3/8" thick. Air sets in 2-4 hours. Heat cure at 200F for 2-4 hours.
not sure what this is but your product worked fine.
the product work fine. we were happy with it. thank you and happy holidays!
EXCELLENT SERVICE
site easy to use.. prompt shipping and expided delivery...product makes excellent repair as marketed...
