Lab-metal 12 oz & 1 Pint Solvent 12 oz
Lab Metal® repair putty
- Ready-to-use aluminum-filled repair and patching compound.
- Spreads like paste, hardens into metal.
- Adheres to metal, wood, plastic, glass, fiberglass and more.
- Apply right from the can. No mixing of two parts, no measuring or heat required.
- Lab-metal can be milled, drilled, tapped, ground and sanded smooth.
Will not shrink or crack. Water resistant, rustproof. Withstands heat to 350°F (higher for one-time powder coating exposures). Thin with Lab-solvent for brushing or spraying. Many applications may be made from a single can -- simply add Lab-solvent before covering. Spreading or shaping Lab-metal (auto body work, sculpturing) is enhanced by keeping applicator moist with Lab-solvent while spreading. Durable, permanent filler for patching seams and cracks; rebuilding worn metal surfaces; repairing dented metal; finishing welds; filling holes and imperfections in metal castings. May be powder coated for single exposures up to 420°F, no longer than 20 minutes.
Packaged in 12 oz., 24 oz.
Hazardous Shipping Info
Excellent Product
As I have used this product in the past I can attest to the quality of this product and the accuracy of the description. My use though has been limited to filling screw and bolt holes that have been stripped or need to be reduced in size and to date have never had any failure of the product as it truly does drill and tap out just like metal. Overall I give this product an A+ and would highly recommend it and although a little pricey is well worth it if you care about quality work/repair.
