"No Boat Should be Without it"
| After proper mixing, AQUAMEND® molds like clay and may be used to patch dings, scratches, cuts, gouges, and holes in fiberglass, metal, and wooden boat decks and hulls; to repair fittings, pipes, electrical connections, leaking gaskets, water tanks, fish boxes, tubs, battery cases, sinks, spas, hot tubs, tanks, pools; to form custom gaskets, etc. |
Aqua Mend
A product which really solves the problem. Can even be mixed under water. Lasts forever and withstands the toughrst environmrnts. No other product comes close .
Best for Aquarium Use
The ONLY Apoxy I use for my saltwater tank. Great working and setting time.
