POWDER COATING MASKING TAPE - 1
POWDER COATING TAPE - 2 MIL
This 2 mil polyester tape has a 1.3 mil coating of a specially cured silicone adhesive that removes cleanly when exposed to temperatures that do not exceed 400 degrees F.
An excellent general purpose tape for powder coating masking.
3 Reviews Hide Reviews Show Reviews
Does what it is supposed to
I coated some adjustable wrenches and used this tape to mask off the surfaces where the sliding jaw goes and the drilled holes. Worked great
Good Stuff
Does exactly whats expected of it, awesome
Like
Good quality
