POWDER COATING MASKING TAPE - 2
POWDER COATING TAPE - 2 MIL
This 2 mil polyester tape has a 1.3 mil coating of a specially cured silicone adhesive that removes cleanly when exposed to temperatures that do not exceed 400 degrees F.
An excellent general purpose tape for powder coating masking.
Great Tape
I bought this 2" roll because I can also use the gasket hole puncher to make dots. Does a fine job and removes easy.
Easy to work with
This stuff works awesome, it's easy to trim and the roll goes a long way.
