POWDER COATING TAPE - 2 MIL
This 2 mil polyester tape has a 1.3 mil coating of a specially cured silicone adhesive that removes cleanly when exposed to temperatures that do not exceed 400 degrees F.
An excellent general purpose tape for powder coating masking.
3 Reviews Hide Reviews Show Reviews
Pretty Good
Works just like it should!
Hasn't let me down yet
I have nothing but good things to say about the argon products the tape works great
Like
Good quality
