High Temperature Masking Tape
Polyimide tape is perfect for high temperature masking needs. Withstands temps up to 600F.
- Copper colored
- Maximum Temperature: 500F
- Total Thickness: 2 mils
- Excellent Electrical Insulation
![This product can ship air and worldwide This product can ship air and worldwide](/content/images/airok.png)
