SILICONE CAP KIT
For Powder Coating, Plating, Anodizing or Painting
Prevent powder coating, plating or anodizing from getting into sensitive areas.
Withstands 600 deg F
Awesome
Works great but sometimes has a tendancy to pop off in the oven. They will catch fire on the oven elements :) They also work good to seal threaded holes
