GREEN MASKING 1/2" DOTS - 2000 PER ROLL
- 2 mil thick, 1/2" Diameter Polyester Dots
- Ideal for masking screw holes etc.
- Perfect for Powder coating, anodizing, plating, painting
- Withstands Up to 400°F
