High Temp PC Tape - 1"
High Temperature Masking Tape
Polyimide tape is perfect for high temperature masking needs. Withstands temps up to 600F.
- Copper colored
- Maximum Temperature: 500F
- Total Thickness: 2 mils
- Excellent Electrical Insulation
