Quick view Caswell sku: SCA1Q SILVER PLATING CONCENTRATE A 1 QT MSRP: Now: $265.09 Add to Cart Compare Quick view EZ-Way sku: SLVRPL26 SILVERPLATER MSRP: Now: $71.49 Add to Cart Compare Quick view Caswell sku: SPED48 SP DEGREASER - 10 LBS MSRP: Now: $68.74 Add to Cart Compare Quick view Caswell sku: SPED18 SP DEGREASER - 2 LBS MSRP: Now: $25.84 Add to Cart Compare Quick view Caswell sku: PNPSSACT STAINLESS STEEL ACTIVATOR - 8OZ MSRP: Now: $18.14 Add to Cart Compare Quick view Caswell sku: SSAG8 STAINLESS STEEL ACTIVATOR FOR GOLD 8OZ MSRP: Now: $14.84 Add to Cart Compare Quick view Caswell sku: SSANODE STAINLESS STEEL ANODE 4" x 8" MSRP: Now: $24.19 Add to Cart Compare Quick view Caswell sku: WANDS4 STAINLESS STEEL BRUSH PLATING WAND MSRP: Now: $8.24 Add to Cart Compare Quick view Caswell sku: CPM25 THE CASWELL PLATING MANUAL MSRP: Now: $30.00 Add to Cart Compare Quick view Caswell sku: TINCON2 TIN PLATING CONCENTRATE - Makes 1.75 Gallons MSRP: Now: $50.59 Add to Cart Compare Quick view Caswell sku: CETIN1Q TINNING SOLUTION - 1 QT MSRP: Now: $130.90 Add to Cart Compare Quick view Caswell sku: TC1 Triple Chrome Plating Kit - 1.5 Gal MSRP: Now: $724.89 Add to Cart Compare Quick view Caswell sku: TC3 Triple Chrome Plating Kit - 4.5 Gal MSRP: Now: $1,233.09 Add to Cart Compare Quick view Caswell sku: YCHRC5G YELLOW CHROMATE SOLUTION - 4OZ MSRP: Now: $39.04 Add to Cart Compare Quick view Caswell sku: ZNANOD20 ZINC AND COPY CAD ANODE 4 x 8 x 0.040 MSRP: Now: $29.99 Add to Cart Compare Quick view SILVER PLATING CONCENTRATE A 1 QT Use in conjunction with Silver Plating Solutions B and Conditioner. (96oz A:10oz B:86oz Distilled Water=1.5 Gals) MSRP: Now: $265.09 Add to Cart Compare Quick view SILVERPLATER A great new way to re-silver: Headlight reflectors knobs, bezels, ornaments, flatware, contacts, etc, etc. For old silver objects, simply apply a small amount of SILVERSMITH or SILVERPLATER to a soft cloth, and rub gently. The part will be etched clean... MSRP: Now: $71.49 Add to Cart Compare Quick view SP DEGREASER - 10 LBS The correct surface preparation prior to plating is of the utmost importance. Slight traces of grease or oil, even finger prints, can completely ruin a good plating job. Yet most commercial systems use harsh alkaline cleaner that are tough to handle and... MSRP: Now: $68.74 Add to Cart Compare Quick view SP DEGREASER - 2 LBS The correct surface preparation prior to plating is of the utmost importance. Slight traces of grease or oil, even finger prints, can completely ruin a good plating job. Yet most commercial systems use harsh alkaline cleaner that are tough to handle and... MSRP: Now: $25.84 Add to Cart Compare Quick view STAINLESS STEEL ACTIVATOR - 8OZ Immerse the part in a solution of 50% muriatic acid and 50% distilled water for 10 seconds at room temperature. Brush plate with Stainless Steel Activator and stainless wand, carefully going over the same area several times. MSRP: Now: $18.14 Add to Cart Compare Quick view STAINLESS STEEL ACTIVATOR FOR GOLD 8OZ Eliminate nickel plating steps and plate gold directly onto stainless steel parts using our Stainless Steel Activator for Gold. Etch with this product, then plate gold directly onto stainless parts. MSRP: Now: $14.84 Add to Cart Compare Quick view STAINLESS STEEL ANODE 4" x 8" Stainless Steel Anode 4" x 8" MSRP: Now: $24.19 Add to Cart Compare Quick view STAINLESS STEEL BRUSH PLATING WAND Stainless Steel Wand for Plug N' Plate Kit For Use With: Nickel Gold Silver Bronze Copy Chrome Black Krome MSRP: Now: $8.24 Add to Cart Compare Quick view THE CASWELL PLATING MANUAL The Caswell Plating Manual Now Version 10 GUARANTEE We guarantee our manual to be the VERY best on the market for a miniature plating operation. If you can show us one better - we'll refund your money! Version 10 of The Caswell Plating... MSRP: Now: $30.00 Add to Cart Compare Quick view TIN PLATING CONCENTRATE - Makes 1.75 Gallons Makes 1.75 Gallons Tin Electroplating Solution. Mix 6.7oz Concentrate, 1 Pint Activator, 2 Qts Battery Acid and 3.5 Qts Distilled Water MSRP: Now: $50.59 Add to Cart Compare Quick view TINNING SOLUTION - 1 QT Caswell Tinning Solution Highly recommended when plating over conductive paints. Resolves a mutlitude of problems including patchy plating and eliminates the need for multiple connecting wires to the part. Adds a conductive coat for high quality ... MSRP: Now: $130.90 Add to Cart Compare Quick view Triple Chrome Plating Kit - 1.5 Gal for Decorative Chrome Watch How To Use This System NOW INCLUDES ZINCATE AND ALUMINUM DEOXIDIZER FOR A COMPLETE ALUMINUM PLATING SOLUTION A revolution in real decorative chrome plating; this new kit has special additives which widen the operating range... MSRP: Now: $724.89 Add to Cart Compare Quick view Triple Chrome Plating Kit - 4.5 Gal for Decorative Chrome Watch How To Use This System - Full DVD Included In Kit NOW INCLUDES ZINCATE AND ALUMINUM DEOXIDIZER FOR A COMPLETE ALUMINUM PLATING SOLUTION A revolution in real decorative chrome plating; this new kit has special additives which... MSRP: Now: $1,233.09 Add to Cart Compare Quick view YELLOW CHROMATE SOLUTION - 4OZ IRIDESCENT YELLOW CHROMATE After preparing the part to accept the process, the part is simply dipped into a solution for a few minutes. The zinc & the chromate react to form the new colors. To improve those older zinc (pot metal) castings,... MSRP: Now: $39.04 Add to Cart Compare Quick view ZINC AND COPY CAD ANODE 4 x 8 x 0.040 Zinc and Copy Cad® Anode 4" x 8" MSRP: Now: $29.99 Add to Cart Compare Previous 4 5 6 7 8 9 10 Next Previous 4 5 6 7 8 9 10 Next Compare Selected × OK
