A great new way to re-silver:
Headlight reflectors
knobs, bezels, ornaments, flatware, contacts, etc, etc.
For old silver objects, simply apply a small amount of SILVERSMITH or SILVERPLATER to a soft cloth, and rub gently. The part will be etched clean and plated with a substantial layer of SILVER within a matter of seconds, as you polish. Rinse in fresh water and dry with a clean soft cloth.
SILVERSMITH or SILVERPLATER can be applied to surfaces made, or plated with, nickel, copper, bronze, brass, zinc. It will NOT work on base metals such as steel and aluminum. (But you could plate these with nickel first). The part should be highly buffed and polished before application.
As this is a real silver plate, it will tarnish gradually as with normal silver plate. A light rub over with a small quantity of SILVERSMITH or SILVERPLATER will soon restore the shine. Reflectors should last several years before needing a further application. Unlike metal polishes, SILVERSMITH or SILVERPLATER actually applies more metal each time you use it. Made with 99.99% pure silver.
SILVERSMITH contains cyanide and can only be sold to businesses.
SILVERPLATER is cyanide free, and works just as well as SILVERSMITH. The silver is applied more slowly.
6 Reviews Hide Reviews Show Reviews
Did not meet my expectations
I had a bottle of this about 15 years ago that was absolutely amazing! I bought a bottle about a year ago and it does NOT turn the same results. I can only assume the formula has been changed, most likely to meet some kind of environmental standards but bottom line, this bottle doesn't work.
Could not achieve the level of plating I desired
The product works but I could not get a real silver plate look on headlight reflectors. Talked to customer support but still no success. I brush plated the brass reflectors and they looked good.
worked
This is awesome stuff. Loved the way it worked
one word awesome
Does what it says and more I am sold for life.
works great
When I got this I didn't think that it would work but boy I was wrong this stuff WORKS .....
this really works
I have used a lot of Polish but this works the best and adds not take away silver.
