Immerse the part in a solution of 50% muriatic acid and 50% distilled water for 10 seconds at room temperature. Brush plate with Stainless Steel Activator and stainless wand, carefully going over the same area several times.
GHS Info
SDS
Kits may contain more SDS than listed here. Contact us for details
Works
Essential for use on SS.
