Zinc and Copy Cad® Anode 4" x 8"Safety Information
10 Reviews Hide Reviews Show Reviews
EXCELLENT PRODUCT
EXCELLENT PRODUCT AND FAST SHIPPING FROM CASWELL Thank you WiperWorks
Copy cad
Excellent imitation on cad , easy to use. Prep work is the key to a good finish.
great anode!
this stuff works good with the 1.5g copy cad kit. they last pretty long too.
awesome products! I always have the best looking finishes when using your products!
these are great!
Perfect size for my home use plating kit! Timely shipping and arrived fine.
Worked well! I'd buy more but it's still going!
I spent some time looking for a zinc source. I looked at zinc boat anodes but no one could tell me the purity, so I bought these as they are the best deal for the guaranteed purity. I bought two, one for each side ad have plated hundreds of dollars in parts with them and only now have burned through the lower half (have them bent over the side for easy moving). Might try boat anodes just to see, but these are a great source if you want no risk.
Great Service!
Extremely FAST shipping and they are exactly what I needed. Also, the folks I talked to on the phone were very knowledgeable and helped me work through the problems I was having and I am now getting great results! Thanks!!!
A+
Got what I ordered.
Good Products
Vary happy with everything from Caswell
