null
Additional Items Required
Get Our Plating Manual
Plating Kits
  • COPPER CONDUCTIVE PAINT - 1 PINT
    Copper Conductive Paint Make non-conductive items such as plastics, resins, leather, ceramics, cardboard, flowers, leaves, roses etc. conductive so they can be plated. Copper Conductive Paint is an inexpensive alternative to our highly conductive...
    $178.37
    Add to Cart
  • COPPER CONDUCTIVE PAINT - 4OZ
    $55.65
    Add to Cart
  • COPPER CRYSTALS W/BRIGHTENER 1.5 GAL
    Add 1 Bag Copper Crystals to 176 fl oz distilled water.Add 16 fl oz Battery AcidAdd 1.5 fl oz Copper Brightener A and 0.3 fl oz Copper Brightener B.Plate a piece of scrap brass or copper for approx 1 hour at required current (0.07 amps per square inch)
    $82.85
    Add to Cart
  • COPPER CRYSTALS WITH BRIGHTENER 20 Gal - 33 lbs
    Makes 20 Gallons of Acid Copper Plating Solution Add to 213 fl oz Battery Acid 18.3 Gal Distilled Water 20 fl oz Copper Brightener A 4 fl oz Copper Brightener B Plate a piece of scrap brass or copper for approx 1 hour at required current (0.07 amps per...
    $370.63
    Add to Cart
  • Copper Stripping Kit - 1 Gal
    Copper Stripping Kit The copper stripping kit contains everything you need, except a DC power supply, to strip copper from aluminum and steel. 1 Gallon Kit Contains: 2 Gallon Tank and Lid 2.5 lbs MetalX Copper Stripper (makes 1 gallon) 2 x Stainless...
    $123.96
    Add to Cart
  • Copper Stripping Kit - 2 Gal
    Copper Stripping Kit The copper stripping kit contains everything you need, except a DC power supply, to strip copper from aluminum and steel. 1 Gallon Kit Contains: 3.5 Gallon Tank and Lid 5 lbs MetalX Copper Stripper (makes 2 gallons) 2 x Stainless...
    $151.79
    Add to Cart
  • Copper/Chrome Combo Kit - 1.5 Gal
    Includes a 1.5 Gal Acid Copper Plating Kit and a 1.5 Gallon Chrome Plating Kit. This combo kit is only useful for upgrading a nickel plating kit to a Triple Chrome Plating System. If you already have a Nickel Electroplating Kit, and you want to Chrome...
    $416.17
    Add to Cart
  • Copper/Chrome Combo Kit - 3 Gal
    Includes a 3 Gal Acid Copper Plating Kit and a 3 Gallon Chrome Plating Kit. This combo kit is only useful for upgrading a nickel plating kit to a Triple Chrome Plating System. If you already have a Nickel Electroplating Kit, and you want to Chrome Plate...
    $694.47
    Add to Cart
  • Copper/Chrome Combo Kit - 4.5 Gal
    Includes a 4.5 Gal Acid Copper Plating Kit and a 4.5 Gallon Chrome Plating Kit. This combo kit is only useful for upgrading a nickel plating kit to a Triple Chrome Plating System. If you already have a Nickel Electroplating Kit, and you want to Chrome...
    $944.94
    Add to Cart
  • Copy Cad & Zinc Plating Kit - 1.5 Gal Copy Cad & Zinc Plating Kit - 1.5 Gal
    Copy Cad® & Zinc Plating Kit All the benefits of CADMIUM & ZINC PLATING without the dangers!  No cyanides! No dangerous chemicals! No fumes! No disposal problemsSacrificial (cathodic) coating – Just like real Cadmium &...
    $320.85
    Choose Options
  • Copy Cad & Zinc Plating Kit - 15 Gal Copy Cad & Zinc Plating Kit - 15 Gal
    $1,781.35
    Choose Options
  • Copy Cad & Zinc Plating Kit - 3 Gal Copy Cad & Zinc Plating Kit - 3 Gal
    Copy Cad® & Zinc Plating Kit All the benefits of CADMIUM & ZINC PLATING without the dangers! No cyanides! No dangerous chemicals! No fumes! No disposal problemsSacrificial (cathodic) coating – Just like real Cadmium & Zinc!...
    $366.85
    Choose Options
