Makes 20 Gallons of Acid Copper Plating Solution
Add to
- 213 fl oz Battery Acid
- 18.3 Gal Distilled Water
- 20 fl oz Copper Brightener A
- 4 fl oz Copper Brightener B
Plate a piece of scrap brass or copper for approx 1 hour at required current (0.07 amps per square inch)
GHS Info
SDS
3 Reviews Hide Reviews Show Reviews
loved it
Worked even better than I hoped
nice kit
Great set up will buy again.
nice kit
