Add 1 Bag Copper Crystals to 176 fl oz distilled water.
Add 16 fl oz Battery Acid
Add 1.5 fl oz Copper Brightener A and 0.3 fl oz Copper Brightener B.
Plate a piece of scrap brass or copper for approx 1 hour at required current (0.07 amps per square inch)
GHS Info
SDS
Delivered on time and works as stated.
