Includes a 4.5 Gal Acid Copper Plating Kit and a 4.5 Gallon Chrome Plating Kit.
This combo kit is only useful for upgrading a nickel plating kit to a Triple Chrome Plating System. If you already have a Nickel Electroplating Kit, and you want to Chrome Plate your parts, this kit is for you.
4.5 Gallon Kit:
- 2 x 6 Gal Plating Tanks & Lid
- 2 x Copper Anodes 4" x 8" and bandages
- 3 Packs Copper Crystals (Makes 4.5 Gals)
- 10 x 1.5oz Copper Brightener A
- 1 x 4oz Copper Brightener Part B
- 2 x 12" x 12" Chrome Anodes
- 3 Cans Chrome Crystals (Makes 4.5 Gals)
- Chrome Activator
- Mist Control Balls
- 1 x Pump Filter/Agitator
- The Caswell Plating Manual
- Free Technical Support
Not available to residents of California unless an appropriate permit has been obtained. Use REPROCHROME® instead.
Recommended Skill Level
Advanced level products require multiple steps to achieve end results, such as conductive paints, or multiple cleaning steps. While many novice customers have used these products successfully in the past, we recommend some experience using easier processes before trying an advanced level product.
Hazardous Shipping Info
GHS Info
SDS
great set up
Great kit, looks awesome
