Makes 10 Gallons Acid Copper Plating Solution
Add to:
- 106 fl oz Battery Acid
- 9.2 Gallons Distilled Water
- 10 fl oz Copper Brightener A
- 2 fl oz Copper Brightener B
GHS Info
			 SDS
                fantasticWorks well without clumping or losing its soluability. No crystals at bottom of bath and i've used it for over 8 months
