null
Get Our Booklet
Buffing Wheels
See all of our buffing wheel products here
Unsure how to use these wheels - read our FREE How To Buff and Polish Booklet now.
  • 32 PLY CUSHION BUFF - 8 Inch
    These buffs are sewn with two rows to slightly stiffen the buff. This improves the speed of the final coloring operation, giving you performance somewhere between a spiral sewn and a loose wheel.
    $14.99
    Choose Options
  • CANTON FLANNEL WHEEL - 10" X 1/2"
    Canton Flannel is very soft, and this wheel is loosely stitched, so the layers of cloth flare out to give a wide angle ultra smooth polishing surface. Generally used with the BLUE or RED compound, this wheel can be used on the most delicate items such as...
    $8.79
    Choose Options
  • CANTON FLANNEL WHEEL 4 X 1/2
    $3.84
    Choose Options
  • CANTON FLANNEL WHEEL 6 X 1/2
    $4.94
    Choose Options
  • CANTON FLANNEL WHEEL 8 X 1/2
    $7.14
    Choose Options
  • CLOTH FINGER BUFF - SOFT
    A highly agressive wheel for quick cutting and polishing. Ideal for buffing contoured items. Made of tough, long lasting cloth. Use with any cutting compound, or greaseless compound. Very economical to use.  Wheels have a metal center with 3/4" hole...
    $9.89
    Choose Options
  • DENIM BUFFING WHEEL - 4" x 1/2"
    Our newest buffing wheel, the denim buffing wheel, is soft enough for any buffing application that calls for cotton wheels, but, because of the sturdy denim construction, it lasts much, much longer than a cotton buff. The faces of these wheels are...
    $7.69
    Choose Options
  • DOMET FLANNEL WHEEL - 4" X 1/2"
    Domet flannel is very the softest available material, and this wheel is loosely stitched, so the layers of cloth flare out to give a wide angle ultra smooth polishing surface. Generally used with the BLUE or RED compound, this wheel can be used on the...
    $3.84
    Choose Options
  • DOMET FLANNEL WHEEL - 6" X 1/2"
    $4.94
    Choose Options
  • FACER BUFF - 2.5
    FACER BUFF - 2.5
    Facer buffs are similar to Mushroom buffs, except that the have a flatter surface. They are partularly usefull for buffing and polishing larger flat areas such as primary covers on motorcycles. Use with liquid or bar compounds.
    $7.69
    Add to Cart
  • FACER BUFF - 3.5
    FACER BUFF - 3.5
    $8.79
    Add to Cart
  • FACER BUFF - 4.5
    FACER BUFF - 4.5
    $9.89
    Add to Cart
  • FELT WHEEL - HARD 6 X 1
    Ideal for many uses including woodworking, gunsmithing, knife sharpening, jewelry work etc. These firm felt wheels won't splay out or fray, making them ideal for the applications above. Long lasting and quick working. Use with white compound for most...
    $36.29
    Add to Cart
  • FELT WHEEL - HARD 6 X 3/4
    $26.94
    Add to Cart
