Facer buffs are similar to Mushroom buffs, except that the have a flatter surface. They are partularly usefull for buffing and polishing larger flat areas such as primary covers on motorcycles. Use with liquid or bar compounds.![This product can ship air and worldwide This product can ship air and worldwide](/content/images/airok.png)
