BALDOR 3HP 3000/3600RPM BUFFER
Made In The USA by Baldor Electric Co.
Includes flanges and nuts
Shipping Weight: 156 lbs
Shaft Diameter: 1.25""
Horsepower: 3
Voltage: 230
Hertz: 60
Phase: 3
Amps: 7.4 amps
RPM: 3000/3600
Max Wheel Size: 2 inches
Wheel Width Min/Max: 0.38"/2"
Bearings: 6206
UL Listed: Yes
CSA Certified: No
Item Code: BD1253
