Light Duty Cast Iron Buffing and Polishing Machine
1/2HP 3450RPM Motor 120/240V
- Easily remove scratches and other imperfections, brings out the natural luster of the metal, and can effectively clean, polish, finish, and buff a wide variety of materials
- Each unit is equipped with a strong, powerful motor that supplies the necessary torque for start-up and operation under load
- Large diameter armature shaft with shielded bearings for smooth operation
- Heavy duty cast iron construction for vibration free operation
- CSA approved OSHA compliant
- 1/2 Inch Diameter Shaft
- 120V 5 amp draw / 240V 2.5 amp draw - Single Phase
- 22 lbs
- 3 Year Warranty
- Does not include buffing wheels
