Baldor 3/4-1/2HP 3600/1800 RPM Buffer 115 VAC/60Hz
Made In The USA by Baldor Electric Co.
These industrial buffing machines are the cream of the crop, and are covered by the manufacturer's 3 year warranty. We sell the complete range of Baldor buffers. If you want an item you don't see here, please contact us.
Baldor Buffer products are warrantied for 3 full years against burnouts, defective material and workmanship. Warranty covers all parts except those subject to normal wear such as wheels. For warranty service, ship the buffer, prepaid, to your nearest Baldor Service Center.
