10" 1.5HP Variable Speed Buffer 900-3600 RPM
These deluxe variable speed buffers deliver the power, precision and versatility to handle a wide range of finishing applications. At maximum rpm's they are built for intermediate blending, polishing and surface conditioning applications. At the lower rpm range they effectively handle the more delicate final finishing, polishing, buffing and surface finish refinement operations.
- Equipped with the latest technology variable speed inverter delivering a broad range of continuous speeds to fit any application
- Powerful, heavy-duty capacitor motors provide additional torque and provide plenty of power at all speeds without any loss of rpm's at full load
- LED speed readout with "soft" touch on/off and variable speed control pad
- 3 hard speed switch settings 900 / 1800 / 3000 RPM. Press the high or low switch button on touch pad to variably adjust the speed up or down in 100 RPM increments from the hard rpm setting
- Dynamically balanced rotors and sealed bearings to minimize vibration and ensure smooth running operation
- Extended wheel to wheel clearance
- 1.5HP 900RPM - 3600RPM in 100 RPM intervals
- One Inch Shaft Diameter
- 115V/14Amps or 240V/7 Amps
- 3 Year Warranty
- Does Not Include Buffing Wheels
