Made In The USA by Baldor Electric Co.Includes flanges and nuts
Shipping Weight: 60lbs
Shaft Diameter: .875""
Horsepower: 1
Voltage: 115
Hertz: 60
Phase: 1
Amps: 5.4
RPM: 1800
Max Wheel Size: 10 inches
Wheel Width Min/Max: 0.38"/1.25"
Bearings: 6206
UL Listed: Yes
CSA Certified: No
Item Code: BD407B
230V Unit Also Available. Call to Order
