Palmgren's 12" 2-speed buffer provides fast and effective deburring, finishing, graining, surface conditioning, polishing and buffing. Designed to run convolute wheels, wire wheels, flap wheels, nylon wheels, fiber or bristle-brush wheels as well as buffing and polishing wheels this buffer/polishing lathe will handle the most demanding polishing applications as well as fine detailing work.
| Abrasive Finishing Type | Bench Grinders and Buffers |
| AMPS | 8.0/9.0 |
| Bench Grinder And Buffer Drive | 2 Speed |
| Country Of Origin | US |
| Max. Buffing Wheel Capacity | 3" |
| Motor HP | 3/1.5 |
| Phase | Three |
| RPM | 3450/1720 |
| Shaft Diameter | 1-1/4" |
| Voltage | 230 |
| Warranty | 3 Year |
| Wheel Diameter | 12" |
| UPC | 726896821054 |
| Unit Of Measure | EA |
| Product Height (In) | 33 |
| Product Length (In) | 39.5 |
| Product Width (In) | 33 |
| Product Weight (Lbs) | 220 |
