Grinder Specifications:
- Free Speed: 22000 RPM
- Capacity: 1/4"
- Overall Length: 6.25"
- Air lnlet (PT): 1/4"
- Air Hose(ID): 3/8"
- Air Consumption: 5 CFM
- Recommended Air Pressure: 90 PSI
- CE Certified
- 90 Day Limited Warranty
Kit Contains:
- ST-7733 Die Grinder
- 5 x 1/8" Grinding Stones
- 5 x 1/4" Grinding Stones
- 2 Wrenches
- 1 x 1/8" Collet
- Case
