QUIKCOPPER EPOXY
"The Plumber in a Tube"
QUIKCOPPER® is a hand kneadable, copper reinforced, epoxy putty that mixes in just one minute to provide fast repairs to pipes, tanks, and vessels made of copper, brass, bronze, and other non-ferrous metals. It comes in a handy four-ounce "tootsie-roll" form with the curing agent encapsulated in the contrasting color base material.
- Repairs copper, brass, bronze and other ferrous metals
- Repair plumbing leaks in 15 minutes
- Bonds to damp and slow leaking surfaces
- Seals leaks in pipes, elbows, joints, sleeves, traps and drains
- Great for freeze breaks
