"Fix it Fast and Make it Last"
QUIKALUMINUM® is a hand kneadable, non-rusting, aluminum reinforced, epoxy putty that mixes in just one minute to repair aluminum easily and efficiently. It comes in a handy four-ounce "tootsie roll" form with the curing agent encapsulated in the contrasting color base material. The putty-like consistency eliminates drips and runs, providing "no mess" applications with no tools required for use.
Â
