QUIKPLASTIK EPOXY
"The Flexible Solution for Plastic Repair"
QUIKPLASTIK® is a hand kneadable, fast setting epoxy putty that bonds to all major plastic types except polyolefins. When mixed, QUIKPLASTIC® is the consistency of modeling clay and can be molded into shapes, wrapped around or used to build up and repair just about anything made from many rigid or semiflexible plastics. After mixing, the color of the putty fades to white.
