ULTRASONIC JEWELRY CLEANER - 1 PINT
Provides a sparkling, like new clean to jewelry when used with an ultrasonic cleaner.
Pour in enough solution to cover the items. If the cleaner has a heater function, turn it on for best results. Run the cleaner for 3 minutes. Rinse in tap water after cleaning.
Solution can be reused hundreds of times.
NEVER CLEAN soft, porous items such as pearls, emeralds, turquoise, opals, amber, foil backed glass. If in doubt, please consult a jeweler.
1 Pint Bottle.
