Turbo Cartridge Case Cleaning Solution
- Scientifically formulated for cartridge case cleaning
- Designed for use in the Lyman Turbo Sonic Ultrasonic cleaner
Mixing:
Light Duty: 1/2oz to 20oz water
Heavy Duty: 1oz to 20oz water
Tap water can be used, but for best results, use distilled water.
4 fl oz bottle.
