null
Everything For Firearms
  • ALUMINUM BLACKENER A385
    Aluminum Blackener A385 Ideal For Touching Up Black Anodized Parts Vary the color from a rich pewter gray to a deep black by changing dilution and immersion times. Completely colorfast through age or sunlight. Very stable under a lacquered finish...
    $31.61
    Add to Cart
  • Black Oxide Gel Kit
    Black Oxide Gel Kit
    Easily spot blacken steel (not stainless) or iron. Simply apply the black oxide gel where you want the blackening to occur. The gel keeps the blackener in place. Leave it on the part for 1-3 minutes and rinse off. Seal with Caswell Sealer for a dry...
    $31.61
    Add to Cart
  • Black Oxide Kit - 1.25 Gal Black Oxide Kit - 1.25 Gal
    Blacken Steel Or Iron Parts At Room Temperature This new technique was developed by the commercial gun blue manufacturers as a more environmentally friendly system than the commonly used hot application. Parts requiring blackening are simply placed in...
    $102.34
    Choose Options
  • Black Oxide Kit - 2.5 Gal Black Oxide Kit - 2.5 Gal
    Blacken Steel & Iron Parts At Room Temperature This new technique was developed by the commercial gun blue manufacturers as a more environmentally friendly system than the commonly used hot application. Parts requiring blackening are simply placed in...
    $188.59
    Choose Options
  • FELT WHEEL - HARD 6 X 1
    Ideal for many uses including woodworking, gunsmithing, knife sharpening, jewelry work etc. These firm felt wheels won't splay out or fray, making them ideal for the applications above. Long lasting and quick working. Use with white compound for most...
    $36.29
    Add to Cart
  • FELT WHEEL - MEDIUM 6 X 1
    $30.24
    Add to Cart
  • Hard Chrome Plating Kit - 1 Gal
    Hard Chrome Plating Kit Chrome plating can be used for two purposes: Hard Chrome Plate Usually used to build up shafts or areas on steel that are subject to severe wear. The hard chrome plating process can take several hours to build up. The procedure...
    $207.45
    Add to Cart
  • Jumbo Buffing Compound Starter Pack
    Our buffing and polishing compounds are manufactured from high quality ingredients, designed for the industrial plater/polisher to obtain fast exceptional quality finishes. The Jumbo bars are approximately 2" x 2" x 8" & weigh approx. 3 lb. each. The...
    $92.33
    Add to Cart
  • Large Buffing Compound Starter Pack
    $61.34
    Add to Cart
  • Nickel Electroplating Kit - 1.5 Gal Nickel Electroplating Kit - 1.5 Gal
    Improved More Complete Kit - New, Bigger Sizes Learn How To Nickel Plate Using This Kit With Our New E-Class - Now Available Enroll In Our E-Class For Free When You Purchase A Nickel Plating Kit* Read More About Our E-Class Here - $99.00 Accessory...
    $346.60
    Choose Options
