Nickel Electroplating Kit - 1.5 Gal
Improved More Complete Kit - New, Bigger Sizes
Learn How To Nickel Plate Using This Kit With Our New E-Class - Now Available
Enroll In Our E-Class For Free When You Purchase A Nickel Plating Kit*
Read More About Our E-Class Here - $99.00 Accessory Package and Power Supply Recommended When Taking E-Class
* - US Customers Only. Purchase Of $99 Accessory Package and Power Supply recommended for full E-Class experience. Read More Here
NEW! IMPROVED PERFORMANCE NICKEL PLATING KIT
Larger Anodes – give more plating, with more even results
Plates up to 60 sf of decorative Nickel
Read This Article From Walnecks Cycle Trader About Our Nickel Kit
Nickel plate has a very slight yellow color to it, but in many applications, if polished, it can double as a chrome plate.
All our chemicals are pre-weighed, so all you have to do is to add distilled water. We have tried to keep the processes as simple as possible and have standardized everything wherever we can.
The kit will plate onto steel, copper, bronze, brass, zincated aluminum, activated nickel, activated Stainless, Flash Copper™, or Bright Acid Copper. This system is too acidic for pot metal, which should be plated first in Flash Copper™.
Nickel plate may also be applied over a copper plate, and copper plate will adhere to the nickel. We suggest you apply copper plate to any areas with large scratches or pits, repair them using our solder-it pastes and then nickel plate them. By buffing the copper plate before nickel plating, you can achieve a very high quality finish, similar to 'Show Chrome". If this nickel finish is then chrome plated, the part will be 'Show Chrome'.
All instructions and operating procedures are detailed in the Complete Plating Manual. Each anode will plate about 32 sq. ft of surface area at 0.0005" before it needs to be replaced. The solution is virtually permanent. No waste chemicals or dangerous fumes are produced.
Nickel Plated Brass Alignment Tool
1.5 Gallon Kit Contains:
- 2 x 2 Gal Plating Tank & Lids
- 2 x 6" x 8" Nickel Anodes and Bandages
- 1 x 2lb SP Degreaser (Makes 4 Gal)
- 1 Pack Nickel Crystals with brighteners (Makes 1.5 Gal)
- 1 x Pump Filter/Agitator
- The Complete Plating Manual
- Free Technical Support
- NO HEATERS INCLUDED
GHS Info
SDS
8 Reviews Hide Reviews Show Reviews
Works Great
Bought this kit along with the Plating Class. I successfully nickel plated very nicely. The class was exceptionally helpful.
nice bundle
Great kit works great am very happy
great set up
Works good and looks good to very happy with my kit
5 stars
Very happy with my kit and was easy to use
5 stars
Very happy with my kit and was easy to ise
great buy
Nice set up works like a charm looks even better
nice kit
Very pleased with mine
this kit works great
Nice kit works great
