null
Plating Hardware and Accessories
  • 10.0 PH BUFFER SOLUTION
    DIGITAL PH TESTER FOR PLATING SOLUTIONS Accurately measures pH ranging from 0-14 pH. Pocket-sized, lightweight instrument will quickly test all your plating solutions, and even your swimming pool water. The unit is splash-proof, and has one point...
    $7.58
    Add to Cart
  • 4.0 PH BUFFER SOLUTION
    $7.58
    Add to Cart
  • 7.0 PH BUFFER SOLUTION
    $7.58
    Add to Cart
  • SALE
    Casweld™  AL Aluminum Brazing Rod Kit
    Casweld™ AL Aluminum Brazing Rod Designed for joining all brazable grades of aluminum sheet, plate, tubing and piping, extrusions, rod and wire 5 Rod Kit (1/8" x 18") & 2 oz Flux Download our Casweld™ Product Manual Perfect for: ...
    MSRP: $56.93
    Was: $56.93
    Now: $44.00
    Add to Cart
  • SALE
    Casweld™  PM Soldering Rod Kit
    Casweld™ PM Soldering Rod 350°F Melting Rods For Pot Metal and Thin Aluminum 4 Rod Kit (1/8" x 18") & 2 oz Flux NOW REPAIR POT METAL PARTS BEFORE PLATING WITHOUT DRILLING OR PUTTIES Download our Casweld™ Product Manual Perfect for: ...
    MSRP: $56.93
    Was: $56.93
    Now: $44.00
    Out of stock
  • Casweld™ Silver Solder Rod - 3/64 x 1 Rod
    Casweld™ Silver Solder Rod Download our Casweld™ Product Manual For color matching stainless steel and for low temperature high strength joints in the food, medical and pharmaceutical industries 1 Pre-Fluxed 3/64" x 18" Rod Features: ...
    $44.28
    Out of stock
  • Casweld™ Silver Solder Rods - 1/16 x 2 Rods
    Casweld™ Silver Solder Rods Download our Casweld™ Product Manual For color matching stainless steel and for low temperature high strength joints in the food, medical and pharmaceutical industries 2 Pre-Fluxed 1/16" x 18" Rod Features: ...
    $125.24
    Add to Cart
  • ELECTRONIC PH TESTER
    $64.50
    Add to Cart
  • LITTLE GIANT BORON NITRIDE PUMP
    Designed for use with our Boron Nitride Electroless Kits, or for pumping any high temperature (up to 200°F) liquid. Brand Name: Little Giant 580603 Magnetic Drive Pump Power Rating 1/30 HP Voltage @ 60 Hz 115V AC Power Cord Length: 6 foot ...
    $598.33
    Add to Cart
  • Mist Control Balls - 2 sq ft
    Due to the high current usage during chrome plating, a mist of acid is produced from the tank. This can become a nuisance due to the corrosive nature of the product and its yellow stain. The Complete Plating Manual shows how to control...
    $51.22
    Add to Cart
