LITTLE GIANT BORON NITRIDE PUMP
Designed for use with our Boron Nitride Electroless Kits, or for pumping any high temperature (up to 200°F) liquid.
- Brand Name: Little Giant 580603
- Magnetic Drive Pump
- Power Rating 1/30 HP
- Voltage @ 60 Hz 115V AC
- Power Cord Length: 6 foot
- Current Rating 1.7 Amps
- Outlet 1/2 Inch MPT
- Inlet 1/2 Inch FPT
- Maximum PSI 30
- Maximum Head 14.6 Feet
- Maximum Temperature 200 F
- Height 5 Inches, Length 9 Inches, Width 4 Inches
- Weight 7 lbs
