Casweld™ Silver Solder Rod - 3/64 x 1 Rod
Download our Casweld™ Product Manual
For color matching stainless steel and for low temperature high strength joints in the food, medical and pharmaceutical industries
1 Pre-Fluxed 3/64" x 18" Rod
Features:
- Super active flux coated cadmium free silver brazing alloy with 56% silver content
- 3/64" (1.2mm) diameter for precision work.
- Special "Fast Flow" flux coating provides twice the base metal cleansing action of conventional silver flux coatings.
- No odors from rubberized compounds yet the flux coating is totally flexible and non-fragile.
- The only flux coated silver flux strong enough to clean oxidized stainless steel.
Tensile Strength: 71,000 PSI (490 MPa)
Yield Strength: 60,000 PSI (415 MPa)
Elongation: 25%
Conductivity: 14.3
Density: 9.59/cm
Hardness: Brinell 130
Welding Techniques:
After cleaning metal, preheat generally to 350F (200C) then heat the joint area to 800F (420C). Melt off some flux and allow it to flow throughout the joint. Then add alloy.
MADE IN THE USA
GHS Info
SDS
