Casweld™ AL Aluminum Brazing Rod
Designed for joining all brazable grades of aluminum sheet, plate, tubing and piping, extrusions, rod and wire
5 Rod Kit (1/8" x 18") & 2 oz Flux
Download our Casweld™ Product Manual
Perfect for:
- Aluminum Castings
Filling Holes
Building Up Worn Sections Joining Cast To Wrought
Joining Thick Parts to Thin Parts
- Casweld™ AL can be anodized
Tensile Strength: up to 35,000 PSI (250 MPa)
Bonding Temperature: 800F - 1000F
Brazing Techniques:
Clean the surface and preheat heavy sections. Heat the first 2"-3" of the rod and dip it into the jar of Casweld™ AL Flux. Adjust the torch to a neutral to slightly carburizing mixture face feed into the flame. Apply the alloy drop by drop, moving the torch constantly. Allow to cool and thoroughly remove all flux residues by scrubbing in warm water.
For thin flowing, adjust the torch to 3X carburizing and preheat to a higher temperature. Then touch the end of the rod to the work and continue heating, forcing the molten flux through the joint. Allow the rod to melt off and flow through the fluxed area. Keep the torch moving constantly.
MADE IN THE USA
Recommended Skill Level
Beginner level products can and should be used by anybody, including those who consider themselves not crafty, handy or hands on. Most beginner level products can be used out of the box and can expect results within minutes. It is always important to read the product instructions and description on the web site before use, for example, nearly all of our plating kits require a polished and clean surface before plating.
GHS Info
SDS
