Casweld™ Silver Solder Rods
Download our Casweld™ Product Manual
For color matching stainless steel and for low temperature high strength joints in the food, medical and pharmaceutical industries
2 Pre-Fluxed 1/16" x 18" Rod
Features:
- Super active flux coated cadmium free silver brazing alloy with 56% silver content
- ï‚ŸSpecial "Fast Flow" flux coating provides twice the base metal cleansing action of conventional silver flux coatings.
- ï‚ŸNo odors from rubberized compounds yet the flux coating is totally flexible and non-fragile.
- The only flux coated silver flux strong enough to clean oxidized stainless steel.
Tensile Strength: 71,000 PSI (490 MPa)
Yield Strength: 60,000 PSI (415 MPa)
Elongation: 25%
Conductivity: 14.3
Density: 9.59/cm
Hardness: Brinell 130
Welding Techniques:
After cleaning metal, preheat generally to 350F (200C) then heat the joint area to 800F (420C). Melt off some flux and allow it to flow throughout the joint. Then add alloy.
MADE IN THE USA
Recommended Skill Level
Beginner level products can and should be used by anybody, including those who consider themselves not crafty, handy or hands on. Most beginner level products can be used out of the box and can expect results within minutes. It is always important to read the product instructions and description on the web site before use, for example, nearly all of our plating kits require a polished and clean surface before plating.
GHS Info
SDS
