FILTER PUMP/AGITATOR
Provides constant agitation to plating baths.
3 Reviews Hide Reviews Show Reviews
very good
fast shipping
great little pump
I am doing flash copper plating and when I first started I didn't have the pump hooked up. After I hooked it up I noticed the surface was a lot smoother and the recessed areas plated at the same rate as the rest the part. It also comes with a nice long wand with holes in the side that way the flow can be directed over a large area. It also has a filter which can help if you get particulate and/or dust buildup.
Service beyond your wildest dreams
Caswells service and help in plating is out of this world. Thank you, WiperWorks
