Airbrush Set
Specifications:
- Double Action Trigger for Air-Paint control.
- Precision machined nozzle and fluid cap, suitable for graphic art work.
- Nozzle: 0.3mm
- Required Air Pressure: 15-30 PSI
- Hose Adapter End: 1/4" NPT Female
Kit Contains:
- Airbrush
- 22cc and 50 cc glass jars
- 5 foot air hose
- Adaptor
- Holder
