Quick view Flex-Shaft Co sku: IND56 Industrial Flexible Shaft #5 - 6 Foot MSRP: Now: $791.88 Add to Cart Compare Quick view Flex-Shaft Co sku: IND84 INDUSTRIAL FLEXIBLE SHAFT #8 MSRP: Now: $791.88 Add to Cart Compare Quick view Flex-Shaft Co sku: IND85 Industrial Flexible Shaft #8 - 5 Foot MSRP: Now: $805.79 Add to Cart Compare Quick view Flex-Shaft Co sku: IND86 Industrial Flexible Shaft #8 - 6 Foot MSRP: Now: $834.89 Add to Cart Compare Quick view Caswell sku: JRBC7 JEWELER'S ROUGE COMPOUND JUMBO MSRP: Now: $21.49 Add to Cart Compare Quick view Caswell sku: JRBC5 JEWELER'S ROUGE COMPOUND LARGE MSRP: Now: $17.07 Add to Cart Compare Quick view Caswell sku: STARBC40 Jumbo Buffing Compound Starter Pack MSRP: Now: $92.33 Add to Cart Compare Quick view Caswell sku: STARBC27 Large Buffing Compound Starter Pack MSRP: Now: $61.34 Add to Cart Compare Quick view Formax sku: F515-424 LIQUID ABRASIVE SANDPAPER 120 GRIT MSRP: Now: $82.85 Add to Cart Compare Quick view Formax sku: F515-426 LIQUID ABRASIVE SANDPAPER 180 GRIT MSRP: Now: $82.85 Add to Cart Compare Quick view Formax sku: F515-430 LIQUID ABRASIVE SANDPAPER 320 GRIT MSRP: Now: $82.85 Add to Cart Compare Quick view Caswell sku: LCW1020 LOOSE COTTON WHEEL 10 X 1/2 MSRP: Now: $14.99 Choose Options Compare Quick view Caswell sku: LCW43 LOOSE COTTON WHEEL 4 X 1/2 MSRP: Now: $4.94 Choose Options Compare Quick view Caswell sku: LCW65 LOOSE COTTON WHEEL 6 X 1/2 MSRP: Now: $7.69 Choose Options Compare Quick view Caswell sku: LCW87 LOOSE COTTON WHEEL 8 X 1/2 MSRP: Now: $14.94 Choose Options Compare Quick view Industrial Flexible Shaft #5 - 6 Foot The "Ferrari" of the Flexible Shaft. These shafts are crafted to exacting standards by a team of engineers. Turn your bench grinder into a high powered rotary tool. These industrial strength flexible shafts will perform the toughest of jobs. The #5 model... MSRP: Now: $791.88 Add to Cart Compare Quick view INDUSTRIAL FLEXIBLE SHAFT #8 The "Ferrari" of the Flexible Shaft. These shafts are crafted to exacting standards by a team of engineers. Turn your bench grinder into a high powered rotary tool. These industrial strength flexible shafts will perform the toughest of jobs. The #5 model... MSRP: Now: $791.88 Add to Cart Compare Quick view Industrial Flexible Shaft #8 - 5 Foot The "Ferrari" of the Flexible Shaft. These shafts are crafted to exacting standards by a team of engineers. Turn your bench grinder into a high powered rotary tool. These industrial strength flexible shafts will perform the toughest of jobs. The #5 model... MSRP: Now: $805.79 Add to Cart Compare Quick view Industrial Flexible Shaft #8 - 6 Foot The "Ferrari" of the Flexible Shaft. These shafts are crafted to exacting standards by a team of engineers. Turn your bench grinder into a high powered rotary tool. These industrial strength flexible shafts will perform the toughest of jobs. The #5 model... MSRP: Now: $834.89 Add to Cart Compare Quick view JEWELER'S ROUGE COMPOUND JUMBO Our buffing and polishing compounds are manufactured from high quality ingredients, designed for the industrial plater/polisher to obtain fast exceptional quality finishes. The Jumbo bars are approximately 2" x 2" x 8" & weigh approx. 3 lb. each. The... MSRP: Now: $21.49 Add to Cart Compare Quick view JEWELER'S ROUGE COMPOUND LARGE Our buffing and polishing compounds are manufactured from high quality ingredients, designed for the industrial plater/polisher to obtain fast exceptional quality finishes. The Jumbo bars are approximately 2" x 2" x 8" & weigh approx. 3 lb. each. The... MSRP: Now: $17.07 Add to Cart Compare Quick view Jumbo Buffing Compound Starter Pack Our buffing and polishing compounds are manufactured from high quality ingredients, designed for the industrial plater/polisher to obtain fast exceptional quality finishes. The Jumbo bars are approximately 2" x 2" x 8" & weigh approx. 3 lb. each. The... MSRP: Now: $92.33 Add to Cart Compare Quick view Large Buffing Compound Starter Pack Our buffing and polishing compounds are manufactured from high quality ingredients, designed for the industrial plater/polisher to obtain fast exceptional quality finishes. The Jumbo bars are approximately 2" x 2" x 8" & weigh approx. 3 lb. each. The... MSRP: Now: $61.34 Add to Cart Compare Quick view LIQUID ABRASIVE SANDPAPER 120 GRIT Coat your own abrasive surface with premixed, ready-to-use Liquid Abrasive Sandpaper®. Liquid Abrasive Sandpaper® contains fused aluminum oxide abrasive dispersed in synthetic glue. Use it for setting up polishing wheels, bobs and buffs of canvas,... MSRP: Now: $82.85 Add to Cart Compare Quick view LIQUID ABRASIVE SANDPAPER 180 GRIT Coat your own abrasive surface with premixed, ready-to-use Liquid Abrasive Sandpaper®. Liquid Abrasive Sandpaper® contains fused aluminum oxide abrasive dispersed in synthetic glue. Use it for setting up polishing wheels, bobs and buffs of canvas,... MSRP: Now: $82.85 Add to Cart Compare Quick view LIQUID ABRASIVE SANDPAPER 320 GRIT Coat your own abrasive surface with premixed, ready-to-use Liquid Abrasive Sandpaper®. Liquid Abrasive Sandpaper® contains fused aluminum oxide abrasive dispersed in synthetic glue. Use it for setting up polishing wheels, bobs and buffs of canvas,... MSRP: Now: $82.85 Add to Cart Compare Quick view LOOSE COTTON WHEEL 10 X 1/2 Use with any compound to cut or color your metal. Gets into cracks and crevices better than Spiral Sewn Cotton Wheels. Buffing Compound Aluminum Polishing Kit Spiral Sewn Cotton Wheel Wheel Rake Free How To Buff and Polish Booklet Buffing Wheel &... MSRP: Now: $14.99 Choose Options Compare Quick view LOOSE COTTON WHEEL 4 X 1/2 Use with any compound to cut or color your metal. Gets into cracks and crevices better than Spiral Sewn Cotton Wheels. Buffing Compound Aluminum Polishing Kit Spiral Sewn Cotton Wheel Wheel Rake Free How To Buff and Polish Booklet Buffing Wheel &... MSRP: Now: $4.94 Choose Options Compare Quick view LOOSE COTTON WHEEL 6 X 1/2 Use with any compound to cut or color your metal. Gets into cracks and crevices better than Spiral Sewn Cotton Wheels. Buffing Compound Aluminum Polishing Kit Spiral Sewn Cotton Wheel Wheel Rake Free How To Buff and Polish Booklet Buffing Wheel &... MSRP: Now: $7.69 Choose Options Compare Quick view LOOSE COTTON WHEEL 8 X 1/2 Use with any compound to cut or color your metal. Gets into cracks and crevices better than Spiral Sewn Cotton Wheels. Buffing Compound Aluminum Polishing Kit Spiral Sewn Cotton Wheel Wheel Rake Free How To Buff and Polish Booklet Buffing Wheel &... MSRP: Now: $14.94 Choose Options Compare Previous 9 10 11 12 13 14 15 16 17 18 19 Next Previous 9 10 11 12 13 14 15 16 17 18 19 Next Compare Selected × OK
