| Our buffing and polishing compounds are manufactured from high quality ingredients, designed for the industrial plater/polisher to obtain fast exceptional quality finishes. The Jumbo bars are approximately 2" x 2" x 8" & weigh approx. 3 lb. each. The large bars are 1.25" x 1.25" x 6" and weigh approx. 1.5 lb. each. We believe these industrial size bars represent a better value than the packaged tubes being marketed. |
SDS
Works well on soft metal
Great Product!
Excellent
Excellent final polish for bringing metal to bright brilliance and shine. Leaves metal very smooth. Use with loose cotton wheel
