LIQUID ABRASIVE SANDPAPER 120 GRIT
Coat your own abrasive surface with premixed, ready-to-use Liquid Abrasive Sandpaper®. Liquid Abrasive Sandpaper® contains fused aluminum oxide abrasive dispersed in synthetic glue. Use it for setting up polishing wheels, bobs and buffs of canvas, cotton, felt, leather and wood. Uses: Liquid Abrasive Sandpaper® can be conveniently dipped, brushed or sprayed, on a variety of shapes and sizes of wheels, bobs and belts to create an abrasive surface that can be as firm and hard, or flexible, yielding and resilient, as the underlying surface to which it is applied. The process may be visualized as a leveling, smoothing, and blending operation to remove surface imperfections in the form of Pits, Scratches, Parting Lines, Mold Marks, Tool and Die Marks, Weld Blemishes, Stretched Metal Strains, Burrs or Sharp edges.
